While in queuing traffic, and by queuing I mean 2 hours or more, the revs on my ZS180 begin to build. The idle starts at the normal 750 and slowly goes to 1000, 1250, 1500, 2000, 3000 and all the way to idleing at 5000rpm!
The problem first happened in enroute to Germany when I was stuck in traffic for 2 hours going under Brussels. It then happened again when queuing for Rock am Ring festival. Both times were hot days and i thought it was an issue with temperature.
I have since cleaned out the throttle body as suggested here
http://forums.mg-rover.org/showthread.php?p=3847403
I have also tried cleaning around the IAC as suggested here
http://forums.mg-rover.org/showthread.php?t=279797
I thought I'd fixed it but yesterday it happened again; when the snow (in Leeds) caused my 20min drive into a 4.5 hour epic. I had to dump the car (due to the over reving) after 2 hours and get a lift the rest of the way. This removes the likelihood of overheating as the temp was sub zero.
Any suggestions?
My inlet manifold sounds like a bag of spanners but I'm guessing that won't be related at all?
Thanks in advance.
Any suggestions?
Thanks in advance.
