I did send my reply by mistake to wrong thread. It seems that it have not reached everyone so......:agh:
A true knowledge of the subject is always more than supposition.
Also in this case. ZR 160 front brakes WILL FIT inside of every 15" alu wheel.
Competition or road.
With steel wheels the offset is critical, and might make problems. What I have tested ET49 mm won`t fit but ET30 mm did.Easily. But in rallysport we are not using steel wheels if not pointed by a gun.
I have used for my gravel tyres ( 185 or 195 /65 - 15 ) Revolution 6" x 15" ET35 rims. Strong enough and not expensive. They fit ZR body without any hammering and do made also max. allowed track width in grp. N. As from my picture you can see, there is clearance enough. In my case 8 mm to nearist point.
295 or 300 mm brake disk is max which can be used inside of 15"wheel. depending how slim 4 pot caliber is. S1600, S2000 and WRC rallycars are also using 15" gravel tyres.
In rally use the clearance of 5 mm would be ideal minimum for a club men. We often do hit tarmac edges, huge pot holes, or your head size rocks with full speed. Tyre wont broke but wheel will bend......a lot.
On street car, if the driver is very , very carefull 3 mm might do.
So IN REAL LIFE 15" wheel is ok with ZR 160 front barkes. No problem at all.
All MG brakes suffer about not having many options for real competition pads. Selection for ZR160 front brakes is even smaller. But as always, I do have an alternative pad to use to get more real quality options for rally use.
If Mr. Pugnacious do want to have a info about this he is allowed to send a PM to me.
Snowy
Ps. Nissan Primera P12 2002 - model made in UK use the same Lucas front caliber than ZR 160.
Sorry, should be at ZR 160 brakes thread.
Click image for larger version Name: PA180007.jpg Views: 3 Size: 34.6 KB ID: 15777
The ultimate (biggest ) Std road car front brakes which goes into 15" al-wheel is front brakes from Civic-R ( 2000 - 2005). The disk od is 300 mm, and the caliber is like in ZR 160, but having a bit different size and shape of brake pad. The caliber is tall and that`s why so close to the wheel " center groove" inner surface, that when wheel do hit something hard a smallest bend is enough for immediately touch to the caliber. A lot of broken wheels and calibers in FRC pace note rallies.
Advantage is that every single manufacture have real competition pad for those brakes. :yup:
