1 - 2 of 2 Posts
ive a 2003 mk1 zt tdi. (new fob battery fitted) when i go to lock on the fob (old style) the indicators dont flash but the doors,boot lock. when unlocking the ind flash once and locks unlock.
wont alow me to double lock.(press lock twice) used to.
also when locking on the key it only locks the drivers door.
ive removed the door trim and found one wire broke in the plug going to the actuator.(solderd a new bit in) and still no differance.
also tested the key switch and works on (also tested all other switches and earths)
the plug going to the key switch has a 2 wire plug. oneis earth and the other comes from the alarm box (theres no power on theis wire)
anyone any other ideas and if theres anyone in the north wales area with a t4 to put it on. ta
like i said on the ZR forum, its a fault in the wiring between the alarm box and the so called "rear doors" just cut the purple/white wire that comes out the alarm box and it will work then, or you can pay £40 or what ever it is to plug it into the T4 and find out what i just said :)
1 - 2 of 2 Posts
