1 - 11 of 11 Posts
My race car should rev to 7800rpm which is the max power, but when it gets to 7000rpm it feels like it is hitting a wall. It will still get to 7800rpm but struggles.
Any idea what the problem is ?
It has 2 fuel pumpes, so could it be the ECU.
The engines life before it was put into the ZR was a MGF Cup car were it revved to 8000rpm freely.
did you use the ECU from the cup car if not that will will be your problem as standard ecu's i am sure are capped at 6800-7000
It was changed to a MEMS 3 ZR 190 Trophy ECU.
What is a ZR 190 Trophy? The top spec road ZR's have a hard cut rev limit at 7200 for the 160's and lower for the 120's. I would say its a rev limit in the ECU you need to find the full specs of whatever ECU you have but I have not heard of a 190 trophy, the only 190 cars were the VHPD's running throttle bodies but none of these were mems 3 as they went from mems 2j to OMEX or similar ECU.
so its got the ECU from when you bought the car from the Raine brothers? if it has why not send them an email i was talking to them at the last MG meeting at Oulton Park and seem a very approchable pair
Discussion Starter #6
Already spoke to Tony Raine, he didn't have this problem.
All ZR 190 race cars run mems 3 as do a couple of later built TF race cars....
The limiter is set to 7800 rpm...
the voice of reason!!!
I know that this may sound a bit basic, but it has happened to a couple of the MG Trophy cars in the past.
Is the throttle openning fully. I have know of more than one that just needed a simple readjustment of the cable.
another basic one -air filter -have you tried it with it disconnected?
also what fuel you running on down under?
if its lower octane it won't rev so well
1 - 11 of 11 Posts
