How did you get on, was the noise from tyre wear?Thanks guys will check it out
They check them for play and for rumbling noises when turned by hand but this does not mean they are perfect. Noise at high speed cant be detected at an Mot unless its caused another problem, normally its a dry bearing that whines, this wont be a worn out bearing for many more miles.I have exactly the same drone at that speed. I just put it down to road/tyre noise. I thought wheel bearing at first too but it's just been for MOT and they never mentioned wheel bearings (I assume they check them?).
