1 - 3 of 3 Posts
As in the title,
Does anyone have a spare rear right door handle in XPower Grey they can sell to me?
I've repaired mine, but it was so broken I don't think it will last long.
Simon
Not got one but if you have a look at the pdf I put in the "how to" I can send you one of those repair parts - more area for the epoxy to grip. The ones I've done are all still going well.
Thanks for that Gary, your how to has evolved quite a bit since I first read it way back when I first got my car. I had to use Super Steel epoxy to glue some nuts back on to the handle, the boss had came off and corroded on the bolt. I ended up striping all the grip off it trying to get it off.
Handle is back on now and working. The other part that seems to break easily are the clips that hold the spring assembly on.
Forget vis motors and replacing the clutch hydraulics, the door handles have been the biggest pain in the rear for me.
1 - 3 of 3 Posts
