Hi all!
Not sure where to start with this one... I think my car (ZS 180 mk2) has faulty switches on the VIS motors as it sometimes goes really well throughout the rev range, other times just produces way less power, and occasionally gets upset at around the rpm switch points for the VIS. Sound reasonable?
So, I thought I'd try a fault code reader to see if says anything. I read somewhere a failed VIS motor should produce an error code readable on the OBDII port? However, mine doesn't show any fault codes. Even when I completely disconnect the motors & go for a drive, no code is shown. Not sure if this is normal for the ZS's ECU? It doesn't seem to complain about anything, even disconnecting the TPS does nothing...
Now, the only other thing that occurs to me is that the guy who sold me the car said it had a superchip on it. I wasn't convinced it did as he had no receipt. How would I know if my car has the chip? It certainly pops & bangs on the overrun in 1st gear - don't know if this is normal? Also, does the superchips mess up the error code readings? AND could it be the chip which is causing erratic VIS performance? I haven't had the motors apart yet to see if they're faulty.....
Any thoughts/comments etc much appreciated!!
..Adam
..Adam
