1 - 9 of 9 Posts
Right, this was soldered in almost a month ago now
work fine etc, then the right hand side of lights flicker and come on and off as they see fit
i.e most of the time i dont get either the red or the green light AT ALL!!
A slight bit of pressure on the accelerator make the lights flicker or go off completely
Now, also worth mentioning the lights should be on with ignition on and also for a while after the ignition turned off
The right hand set of lights do not always do what they should do
Would this be a dodgy solder or a dodgy connection, have no issues as far as power in concerned though
Yup, worked fine for about 2 weeks then started to do a wobbly!
It's only since one of my tools got stuck in the throttle cable/housing whilst driving (oooops)
everything looks fine etc, just flickering lights etc, seems really strange
My mate did it for me, would've preferred more solder on the joints for me but...
I don't know anyone that can, no
How to solder
Worth learning, it isn't difficult and means that connections are as one peice rather than two peices touching.
Where was your tool before it got caught up?
Could it have interfered with the connections for the viz indicator.
Discussion Starter · #9 ·
Did think they might of done but it's all wraped up in Tape and in that cable shield stuff so prob not
Confused to be honest, I dunno....
1 - 9 of 9 Posts
