Having read all the threads, I cannot see a way to source and fit a Supercharger. Unlike others I don't want to be a tester?
Therefore, I am asking are there any kits available with a map out there?
1) Kenne Bell - non starter (scooter) not fitting any more.
2) Rousch Kit?
3) Sprintex Kit?
4) Crate engine?
Please only post if you know of a solution, not a maybe. Ta.
the voice of reason!!!
Has Brian at Dreaought fitted any? He has always been good with such things.
He did fit them John. Believe well over 20, but he no longer does them. He is also restricted by Sean Hyland even if he wanted to. Don't know the legal reasons behind it all.
Thread update.
1) Kenne Bell - Personally, I don't understand why Kenne Bell won't warranty the unit, unless there is an inherent problem with it. But the end result is a NO GO as Brian from Dreadnought has said many times. Unless, I signed a piece of paper saying will except responsibility if there was a unit failure. Sold as seen, just as I bought the car.
2) Rousch Kit - possible kit sourced with a map from Jonsmotorsports located over the pond.
3) Sprintex Kit - no info just yet.
4) Crate engine - no info just yet. Too much trouble would be the real answer.
Please only post if you know of a solution. Plus not worried about customs if a kit can be sourced. Maybe something to do in retirement.
