I've stuck this in the 260 section as its one of the weak points that the car will suck the power from the battery if not used regularly.
I have been using two solar trickle chargers on my 260 over the last month or so to see if its worth doing and can report it is. With all the wet weather we have had in the last few months I would have had to top up with the mains fed charger, but no more. I'm getting it free of charge (no pun intended). Admittedly the position of the panels are getting 60 - 70% of sun during the day so the rate is max'ed out for a good period. But with the bits and bobs on the car it is working.
The reason for two was that from discussions people were suggesting one charger would not keep up with the drain from trackers, satnav, etc.
Be interesting to see if the winter months can keep the battery topped up. Will monitor how it goes.
Well worth the £20 spent. From Maplins online store.
