1 - 2 of 2 Posts
Hiya
If its the standard slave on the 180 its easy.
Follow the pipe from the slave cylinder until you locate the connector that connects the slave to the master cylinder. Pul the collar inwards and then pull the connector apart.
The slave itself is only held to the bracket with a plastic C clip. Pull the C clip of the slave cylinder and you can remove the slave from the bracket.
The slave is already filled with fluid so you wont have to bleed the system unless you have lost all you fluid previously.
Hope this helps
Dave
1 - 2 of 2 Posts
