Ahhh. It's good to be back.....
The resevoir in my Sheddist clutch kit is very low. Can I just top it up with my dot whatever brake fluid or do I have to bleed it all and start again. If it's the latter can anyone tell me an easy way?
A top up will be fine.
Elegantly Wasted
Yep just a top up will be fine:)
But if you want to give it a flush through, just get a one man bleed kit. Fit it on bleed nipple on slave and bleed away, the fluid does go pretty discoloured and i found a flush through made a difference. It doesn't take long either:)
Discussion Starter #4
Lovely ta - just topped it up.
There we go then :)
Re: Sheddist clutch kit
Would anyone that has fitted the sheddist clutch kit have any part numbers or bore sizes of the Civic master and slave units that are used. I have pm'd Sheddist several times for the supply of a kit so far no luck, so I thought I would attempt to make the kit myself if I had the Civic master and slave info.
Thanks Cartoys
Discussion Starter #7
I'm ever so sorry - can't help there. Sheddist works abroad a lot so he won't be ignoring you he'll just be busy.
