Hiya all,
Just wondering if anyone with the Sheddist mod to the clutch system has found leaking oil? Just got my car back from a service, and although they replaced a pipe which had a split, I was advised it is leaking (ever so lightly) whenever the clutch is engaged - I think he said at the Master Slave? There's a rubber cover over the top of a rod (clearly I'm not very mechanical).
Before I take it in to be stripped down, thought I'd see if anyone else has had an issue, cause a mate had a similar issue with his.
Or maybe its just the rotten Australian roads causing too much problems :)
Thanks
Matty B
Our first Master Cylinder developed a leak from exactly the same place. Just order a new Master from Nigel and replace it. No need to strip everything down.:)
MKII MGZS180
Mind used to have a leak too at exactly the place you are mentioning and Nigel kindly replaced it for me and fitted as well. Very nice!
