Does anyone know if the actual stub axle is different between the 105 drum set up & 160 disc set up?
I suspect the n/s stub on my 160 race car is bent following an accident a couple of years ago, as on a new rear beam I've 1.7 degrees camber one side & -1.8 degrees the other.
I've a complete rear beam from a drum model & without looking too close (it's not here) I don't know if the stubs are the same.
Thank you
Discussion Starter · #2 ·
Nevermind, answer has been found. Now to check to see if the camber plates are fitted correctly (not fitted by me) or if the stub axle got tweaked when the Armco at Oulton Park got flattened.
