Me and the Mrs have this week been accepted for a mortgage, so all my crap has to go before we find a place... Or so she says!! lol
All of these prices are posted unless stated, and im open to offers on multiple items etc. I will adjust prices accordingly if people wish to collect from Bexley, Kent.
So, here goes!
3 door ZR bumpstrips (in white) £15
160 front subframe £45
220 turbo front subframe £45
220 turbo rear subfram £40 COLLECTED
Non sharkfin ZR spoiler (black, needs painting though) £20
Mk1 front splitter (in white, with end caps) £25
ZR plastic rear inner arches £20
160 rear subframe (seems to have been slightly damaged in storage, cannot remove lower arm as it seems to be been slightly where it fits the subframe) £20 COLLECTED
220 turbo engine mounts £50
Mk1 headlights (one broken clip on drivers) £25
Rover 200 steering column and UJ £25
ZR160 steering column and UJ £25
160 plug cover £10
Full set of door and window seals £45
220 turbo top radiator hose £15
220 turbo loom ( ideally for zr conversion, needs work) £20
ZR lower arm, drivers side £13
All 4 side windows £40
160 ABS unit £18
2x 220 turbo fuseboxes £10 each
2x ZR fuseboxes £10 each
ZR coolant resevoir £10
Approx. 2m high pressure fuel hose £9
ZR rubber rear strut top covers £8
2x exhaust rubbers £5 each
Electric mirror adlustment switch £5
ZR passenger door lock motor £12
ZR passenger window motor (no frame) £12
160 camside rubber mount £10
ZR wiper motor £12
160 camside mount (between engine and rubber mount) £10
620ti cam side mount ( " " ") £10
ZR bonnet hinges £8
160 fuel filter £8
Rover turbo oil filter £8
160 injectors, loom and rail £20
160 starter motor £12
ZR tail lamps £20
ZR roof lining £10 COLLECTED
ZR centre console £14
ZR handbrake surround £10
ZR handbrake £12
ZR hazard switch £4
ZR fog switches (front and rear) £6
ZR window demister switch £4
ZR front indicators £10
MK1 foglight surrounds (in white) £10
Mk1 foglights £15
MK1 bumper (bare, number plate recess smoothed, but has a crack in it, in white) £25 COLLECTED
Wasted spark ECU ( fully decoded by AA Autosport, code number MKC104070) £40
17" Wolfrace Octanes (need a refurb, one has a flat spot, one has a dent, 2 decent tyres, rare wheels once refurbed) £80 COLLECTED
ZR Glovebox £12
ZR dash clock £8
ZR rubber dash cubby mat £8
ZR dash air vents £10
ZR wiper stalks £10
ZR dash cubby pocket £8
ZR wing indicators £8
ZR headlight levelling switch £5
ZR manual wing mirror rubber adjuster covers £4
ZR dash clock surround £5
ZR 3dr kick strips £10
ZR speedo surround £10
ZR electric window control module £10
ZR interior dooe handles £10
ZR exterior door handles (in white) £12
All of this is what I have cleared so far, I still have more to sort out, so if you are after anything then drop me a PM. Thanks for looking guys!
Where the lower ARM connects its slightly bent. Dunno how it happened.
Hubs aren't there.
NSR or both caliper carriers, with pins please! If they are from a ZR160/ZS180.
edit, am posting same request on that ZS breaking thread, apologies if I get a replay from there first.
