Do you mean drivers cubby box?
If so is it just the box or the panel it fits in?
Think I may have one in shed but the pins can be fixed.
Went and broke one of mine about a week after I had it.
If you have a pop riveter its dead easy to make it better than new.
Drill 3.2 mm hole where pin should be, insert rivet with a small washer either side of plastic, use rivet tool to squash rivet but only to point where it grips plastic (not til stem snaps off as usual). Cut stem off a suitable length, drill & glue broken peg onto rivet - assuming you have broken bit, or use something similar.
Edit:
Got one in shed but same problem as your current one. Can repair it as outlined above if you're interested.
Edit 2:
Now fixed.
Pop rivet, washers and a bit of plastic rod pressed into service.
Bit of paint added (though you can't see it when all back together.
