1 - 3 of 3 Posts
I still have my misfire even after changing the plugs and the coil packs and the 3 front bank leads. I have also changed the TPS as well.
I am hoping it may just be the 3 leads at the back bank or the fuel filter maybe. Does this sound right or can anyone suggest anything else that may be the culprit.
It's driving me crazy now!!
Tried a code reader??
My misfire caused by faulty lamda sensors, fuel filter won't help issues though if not changed on regular basis
sod the 6 yr change, it'll never come off properly after 2 years let alone 6!!!
I got one if ya need it, (code reader)
I have stuck it on a code reader and it is coming up with bank 1 sensor 2 which I believe sir is the post cat sensor. Just trying to source another one from scrappy and they have the upstream sensor (I think both pre & post are the same) from a 400, 25 & a tf. Will any of those fit??
Also on a different note I have a replacement manifold coming sometime in the next couple of days, that should be an interesting job!
1 - 3 of 3 Posts
