1 - 20 of 33 Posts
Previously Owned a ZS180 MK2
Tonight I got myself a lovely clutch and slave cylinder kit from Sheddist for fitting to my ZS180.
The car has been off the road for a little bit as the old slave cylinder failed when I arrived at work one day and was parking my car up. Luckily as I say i was at work and so it was just a case of phoning the AA who towed me and the cab back home and I collected another car i had at home.
Well, what do I think of this kit? ...To be frank, I am gob smacked at the build quality of these components that Sheddist has put together. For a kick off, the bracket for the slave cylinder is a lot more substantial looking than the bracket used in the original design. In fact, everything about the kit just shouts quality !
The kit even comes with an instruction booklet on CD that appears to cover just about every part of the fitting process.
Hopefully tomorrow the weather will stay fine and I can have a go at fitting it all to the car.
Hats off to Sheddist for producing these quality kits. I will post an update regarding the fitting in due course.
Great kit:)
Most of us regulars have this kit fitted.
You won't be disappointed. Let's hear your reviews once fitted.:)
I fitted the kit today. It took me around 4 hours, I was not rushing, it could easily be done in 3 hours.
Everything went very smoothly, the instructions provided in the kit are spot on. I read through them last night a few times and then cracked on with the job this morning after popping to Halfords to get myself some fresh clutch fluid.
Only one little problem really. I opted to use the long clevis for the master cylinder. The clip/pin that comes with the kit wanted to turn as the clutch pedal was depressed. I tried to apply a light smearing of grease to the clevis to stop this, but to no avail. In the end I used a hefty cable tie to secure the clip to the fork. However, given the beautiful pedal I now have, I think I could easily change the fork end for the smaller one. I will perhaps try a change of fork end next weekend.
Bleeding was a breeze, with a little bit of initial pressurised help. I could not really get the system to prime that easily from dry, and so a little bit of careful air pressure got things going.
The end result - The best feeling clutch pedal this car has had for a very long time !
This kit is well worth buying if anyone is thinking of getting one - Full marks !!
often cruized never beaten......
same here top bloke. delivered and gave my car a once over too. excelent build quality and fitting instructions.
MG ZS 180 MKI
+3 :friday:
I will need one for my spring re launch of the zed. What price are they now if you don't mind me asking.
Thanks. Another job on my list to make mine as bomb proof as possible. I will pm sheddist soon no doubt.
Lighten up dude
Ditto
- fitted from nearly new and never had a problem 50K this year.
Go Nigel!
P
I got 45k up but it's one of those things whereby I'm keeping my fingers crossed so gotta do it!
won hay-tee
First thing i did when i registered on this website was to ask for a kit :)
In fact i think it was the reason for me registering in the first place :p
I have noticed that its best to half fill the reservoir with fluid, as if you top it right up, you just spit it out under hard cornering/lift off oversteer moments :D
Hi John did you get this kit recently, iv been trying to get hold of sheddist for a while but iv had no joy. Would you know if he still making them up?
1 - 20 of 33 Posts
