On my drivers side window, I'm having difficulty in closing it.
It's catching on the seal. The rubber seal is sort of turning in, so the window lips over it and strains the motor.
It's just the vertical seal nearest the door opening.
Any ideas??
Take the door card off. Check the bolts holding the glass but don't overtighten them. If you are lucky that will fix it, if not you can remove the inside seal off the top off the door card.
I had to do the latter and never got it fixed.
Edit: THis was on a MK1 but I think same applies.
won hay-tee
You used to be able to buy a lube in Halfords just for window seals.
Been a while since i saw it, but its been a long time since i looked for it, last time i had a problem with seals drying out, i used wd 40 :)
