1 - 3 of 3 Posts
Hi and welcome to xpower
If the plastic is cracked it isn't actually repairable but is relativly easy to replace either with a replacment plastic or a glass screen.
Do a search on one of the MGF forums such as http://www.the-t-bar.com/en/forum
James
I saw a clip on u tube of a rear window being replaced in less than 15 minutes. It took me under an hour (but it was the first one I had done). I used a new BAS screen bought on ebay so that the upper part of the existing zip could be used. Unfortunately my 2003 TF had a non standard zip (from new) so I ended up having to change the upper part of the zip (a bit harder to do than the window section) but took an other hour.
1 - 3 of 3 Posts
