Hi!
I have a problem with my zs180, the speedo is not showing the speed, i have the abs light on.
What is the sensor that reads the speed on this car?
I don't have a tester to see the fault code...
Thanks
The ZS 180 uses the abs reluctor rings for the speed signal, it sounds like you may have a cracked ring.
the reluctor rings from the driveshafts are ok on both sides i have checked them.
Do you think that the abs light on means a malfunction that can affect the speedometer?
Do you have any idea what sensor does it use to read the speed? I assume is one of the 4 abs sensors
Looked like a bad contact to the wires under the engine bay fuse box, the abs light went off and the speedometer is working now.
The speed sensor is on rear right wheel
Thank everyone for help
