1 - 1 of 1 Posts
Jonno
Taken from a 2004 MG ZR complete with IB5 box and shafts. This is the later style stronger box with the nicer change - gearbox is mint. Owned the car since new - 60k.
The engine had the H/G done 4 months ago due to early signs developing and since being done the engine has done around 200 miles and then dry stored in the car, in my garage. The stronger MLS gasket was used, head was skimmed and the rocker cover gasket was changed. Fresh oil and filter along with a powder coated rocker cover (see pic). The engine comes with a VVC inlet manifold fitted - had the cylinder head ported to match. The inlet has the bigger 52mm throttle body attached and is included. This mod made a noticable difference from standard - car did a 15.9 1/4 mile at Santa Pod (stripped). Wiring loom and ECU available too if required. Cambelt was done around 5k ago. The car made 120 bhp (hub dyno) with decent exhaust and filter at GWA. Nice little engine, very quick but never abused. Always maintained and never thrashed from cold.
£450 for everything - ready to bolt in and go. All engine ancills available too.
No postage, collection only.
Cheers -07789 816 262.
1 - 1 of 1 Posts
