1 - 2 of 2 Posts
Hi, Does anyone know if there is a specific fuse for the Low Coolant sensor, etc. ?, As mine does not seem to be working. Im not sure if the sensor has failed, or what. The light illuminates on the dash when you first start the car up, but when the level goes too low it doesnt seem to trigger the light to come on and stay on at all?, Just wondering if someone has been tampering with it, as it might of come on before and stayed on.
Whats your thoughts, some WD40 on the connector and reconnect etc. ?
Jackie
Have fitted later tank to my mkI and used the sensor just to earth a lamp. Would guess you could test the circuit by connecting the two wires together and seeing if light comes on.
Theres not an awful lot to the switch, think its got magnetic contacts in and theres a magnet that floats inside the tank.
1 - 2 of 2 Posts
