hi guys, jus wondering if any one could recommend a induction kit? i own a zs mk2 1.6.
any ideas would appreciate
You will have to do a search on threads on here tbh. Most have gone for the inner wing set up which involves a filter and then sourcing your tubing & hoses onto that as there is not a kit out there as such. Mine is a carbon fibre enclosed filter in the engine bay behind the rad but cold air feed is drawn from the inner wing. Whatever, you must avoid an open cone in the engine bay as you will experience heat soak.
Here's mine. It was made by prospeed in Cardiff. A carbon fibre enclosed filter behind the rad but cold air feed consisting of alloy tubing and silicone hose goes out towards inner wing.
