Got the MG bug bad...
Right, odd one. Ive had an aftermarket momo team steering wheel and the horn has been working fine for over a year but its now stop working. Ive checked the connections on the wiring and its fine as is the fuse that controls it under the column. Is there anything else i need to check? I also tried to see if it worked by trying to lock the car with a door open and the horn itself WORKS. Im stuck...
HELP PLEASE :(
As far as I remember the alarm horn is seperate and at the top right hand corner.Simple way to test the actual horn unit is touch two wires + and - direct from the battery on the horn terminal s to see if its actually the horn itself died
been looking in the haynes manual and it shows the horn to be in the passenger arch is this the case?
