Hi guys,
How do you take the front spliter off? I just got my new bumper through and I wanna put the spliter from my existing bumper on to it. Also, how do I gtake the drivers side wing off? Cheers!
dunno about the splitter but my front wing was lose and it appeared to be just bolted on.
inside drivers door where the hinges are and a bolt inside the bonnet where the rear bonnet hinges are located, these were all lose on mine.
sure if you get a torch or during the day you should be able to see where the rest are?
Paul
Is this the 180 body kit?
I suspect the spliter is held on with heavy duty doublesided foam tape.
The wing is held on with several bolts 4(IIRC) on the top, 1 behind the bumper, 1 or 2 by the hinges and 1 at the bottom hidden by the side skirt (I left this one out when I changed my wing.
I have no idea =/ It was already on my car when I got it. I have a 120+ if that helps? What would be the easiest way to take the spliter of?
Also, what would be the easiest way to access the bold under the side skirt?
I used a large screwdriver to lever out the front of the skirt enough to get a ratchet spanner in there, lost the bolt though and didn't replace it.
Thanks Talkingcars. I hall have a go at that When I get the bumper off to change the bumper in a couple of weeks time
