1 - 20 of 27 Posts
MG XPower.
12 months ago I fitted Fog Lights to my TF. At the time I did not want them wired(only for show) But I have decided to wire them so that they work. Where can I get the connector that goes into the Fog Light Bulb?
Can you post up a pic of the bulbholder connection?
I think I might know of a source.
Yep, I reckon I can get you a couple of connectors.
Will need to ask my contacts this week - can you bear with me?
MG XPower.
Yes, there is no rush.
Thanks for your help and time.
Gaz.
The proper wiring loom is NLA. I have been trying to get one for ages but with no success, either new or S/H from a breaker.
Fog lamps are standard for several MGR models so lamp connectors may be easy to find S/H but the rest of the loom is unique to the TF.
I have had to make up my own loom.
MG XPower.
Where did you get the connectors from?
Sheesh, I've forgotten these! I will make a phone call tonight.
I have two - PM me with an address to send them to!
PM recieved - you should get them Tuesday! Depends upon the Postal Service!
Bottom right, second row up, 2 cavity connectors are what you're after.....
Let me know if you have any luck sourcing the Wurth connectors.
I might have something out in the workshop that might work too. No promises though......
Found this connector, but looking at your picture the pin orientation is 90 degrees out.....
1 - 20 of 27 Posts
