1 - 3 of 3 Posts
The 180 has front only as standard, rear is a factory fit option. The Drivers side is on the door and the remainder on the central console above the hand brake. Exactly the same as 45's and Honda Civics. The Drivers side is the only one with a 1 touch function.
Its worth noting that at present they come from the factory with the 1 touch only drawing the window down 3/4 of the way this can be adjusted to all they way by dealers and is an approved fix.
True Brit
I have a 600 with switches in the middle, hate them there. I used to have an 827 which had them on the door, perfect.
1 - 3 of 3 Posts
