Anyone know what the 160 ecu part number is, there are a few listed for a ZR 160 on Rimmers site.
Also which model ZR is a NNN100752 off.
All ZR and TF 160 ecu's are NNN000160, some early MGF Trophy 160 have apart number NNN000100 and then going over to the NNN000160 just before the TF came in.
You can fit all 160 ECU's onto the ZR and it will run fine, if you want to fit a ZR 160 ECU onto an F/TF 160 it will work fine however the engine bay cooling fan will be on constantly as the ECU was not programmed with the extra drive on the board to run the additional fan.
NNN100752 is 16v NON ABS (all 1.1, 1.4, 1.6 and 1.8 120ps models)
Perfect - been looking all over for this.All ZR and TF 160 ecu's are NNN000160, some early MGF Trophy 160 have apart number NNN000100 and <a href="http://www.bcduplication.com" style="color: rgb(0, 0, 0) ! important; text-decoration: none ! important; cursor: default ! important;">custom printed cds</a> to the NNN000160 just before the TF came in. You can fit all 160 ECU's onto the ZR and it will run fine, if you want to fit a ZR 160 ECU onto an F/TF 160 it will work fine however the engine bay cooling fan will be on constantly as the ECU was not programmed with the extra drive on the board to run the additional fan.
