This is what happens when a clutch release bearing siezes.
Grooves in the shaft
The bearing explodes
The clutch release lever was also siezed, i've taken that out and freed it up, just got to put a new clutch in next.
The main fault would be from the seized clutch arm as this is a common problem that will wear the clutch plate out or in your case the bearing.
transmission solutions in doncaster sell modified arms that can be lubed in situ, quite a clever - although simple idea that stops this problem, they were not much money either
Ta for the advice but emery paper and a bit of grease sorted it.
t
Thats what I had done with mine, I was being dead stingy but as it was a track car its likely to have the box out a lot more for work than a road car.
The arms are a bargain if you have a road car, if I never track day'ed mine again I would feel regret about not spending the 20quid or so, especially when looking at the mess in your pics.
best of Luck.
t
best of Luck.
With the amount of miles on my car it's not worth spending money on it tbh though I did replace the diff seals as I had some spare that have been in my garage for over 6 years.
I bought a 3part clutch for £60 and that arrived today. When I find the time in August I will put it on and replace the gearbox. Then a fresh MOT etc for autotesting in September...more abuse of the car
