i seem to keep having problems with climate control seems when its on auto its not working properly, seems to keep blowing fast doesnt seem to settle at all like it used to or warm up properly . but when its on manual i can change fan speeds fine the hot and cold works when i change it but i notice when i press external temp it says its 40 degrees outside when its more like -1 .
any ideas ? cheers luke
The outside temp sensor has gone duff, it is clipped the the l/h foglight bracket.
You'll need to phone or email them, the sensor isn't listed but they can supply them.
To replace it you need to remove the l/h plastic wheel arch liner enough to reach in behind the bumper and un clip it from the foglight mount.
