I have a BRM gearbox for sale. Comes standard with LSD and bolts to any K series engine without modification.
£200 plus p/p
£200 plus p/p
Even 1400 and 1600 K engines normally with R65 boxes where an 'upgrade' is needed?. . . bolts to any K series engine without modification.
even KV6?I have a BRM gearbox for sale. Comes standard with LSD and bolts to any K series engine without modification.
£200 plus p/p
I doubt that a K4 PG1 is strong enough to be fitted to a KV6, but a diff (Torsen or superior Quaife ATBsorry, i forgot you were k6 slags
this will bolt to any k (4) series engine, and yes as pointed out above, if you have a 1.4 or 1.6, you will need to change starter - mount - shafts at least. however, as i said it bolts to any k (4) series engine.
BRM gearboxes use a type B diff, a 3.9 final drive with a close ratio gearset.
you could, build it into a kv6 box, or simply swap the diff into it.
Bargain!
Rover coupe / 620 turbo does your need to change arm and speedo driveeven KV6?
i disagree with that first statement.I doubt that a K4 PG1 is strong enough to be fitted to a KV6, but a diff (Torsen or superior Quaife ATB) is a good mod to have anyway.
B6BSTthey are the same box so....
what code are BRM boxes? the kv6 is a C6 box.
Drew
