What format did you choose for output?Cheers. Alas, that software didn't do the job. It took about 4 or 5 hours to convert one file and the converted file was too big to fit onto a DVD (went from around 1.2gb to 8.8gb)
The converter you're using doesn't burn videos for viewing on a dvd player. All it's done is convert your avi file to a burnable format. You're going to need a separate burner for that.Cheers. Alas, that software didn't do the job. It took about 4 or 5 hours to convert one file and the converted file was too big to fit onto a DVD (went from around 1.2gb to 8.8gb)
cool. but what are you using to burn it?I use WinAVI, not free but it does the job beautifully.
Miss the bleedin' obvious D'ohJust get a 15pin cable (video) and small phono to phono (sound) from your laptop to your tv. Easy peasy, no dvds required.
I just use Nero to burn it on to DVD.cool. but what are you using to burn it?
Glad it worked for you. lol. It's been trying to burn a 1 minute video I fed it for the past half hour. Forced the program to close and now the dvd bay is locked up and flashing! I'll try again after reboot! :<Cheers gents, I got a program called DVD Flick which did the job of converting and burning but it looks like a good tool for creating videos in general.
I did 2 discs, both around 2.5 hours long without any bother and (and I was fumbling around not really knowing what I was doing!). After a few hours I could even play both discs on my xbox 360!Glad it worked for you. lol. It's been trying to burn a 1 minute video I fed it for the past half hour. Forced the program to close and now the dvd bay is locked up and flashing! I'll try again after reboot! :<
