Hi all,
Usually when I start driving, from 3k the car takes off nicely.
However, after a few minutes or if I stop and then restart, it no longer does that and feels slower between 3k and 5k revs.
Its quite annoying as sometimes it feels like it could win an F1 race and at other times feels like it would lose to a Honda Jazz....diesel!*
I have taken the VIS apart several times and checked it works with a 9v battery, sanded the butterfly valve down so it doesn't catch the frame. Is there anything else I can check?
I did wonder if there was some electrical issue that was causing the motor not to get power.
When the motor kicks in, does it open or close the valve?
If it opens the valve, can I remove the butterfly and go for a test run to see if it is ok then?
Ideas. Please.
*I have never raced a Honda Jazz but feel if I did I would beat it quite easily. I am not a boy racer either. Much.
Ideas. Please.
