I forget what it is and most importantly, where from??
Needs doing as sure it was replaced with lesser oil and can hear the difference
MTF 94 Tranmission Fluid Oil
Available from various places, it is spec'd for Landrovers so most LR dealers should be able to get it. Alternatively I just typed it into google and ebay and found loads of suppliers depending on your brand of choice :)
how many litres do I need?
MG ZS 180 MGB GT V8
Is 5.5 litres not the engine oil capacity ? I'm sure when I changed the gearbox oil it was only a litre or two, I don't have a manual at work to check but I'll look at the Haynes book tonight.
yes you are correct, I'd mixed up the values... 5.5 litres ENGINE oil, 2.2 litres GEARBOX oil. There is amanufactureres spec sheet on here already....
http://www.xpowerforums.com/MG_ZS180_Tech'.htm
Appologies james for my cock-up :)
rave says: PG1 . Texaco MTF 94 (unipart MTF 94), Caltex MTF 94 - refill or top up use viscosity oil 10w/40 - volume from dry 2,2L.
