does anyone know what size 18's i would need to fit straight to the mg zs180 mk2?
Cheers buddy im after the off sets too want to go a bit wider than standard 205 hoping for 215/225 to improve the stance. =)
i'll check on my 18s, they stick out a bit more, i think theyre a 36 offset no problem with 18s on a zs, ive got 30mm spacers on my track zs with standard wheels and they fit
I have tsw 4x100 et35 7x18" on my zs180 mk2 (prev on mk2 hatch)
over bumps with weight they will rub on the rear arches, just slightly.
that was with 215 35 18 tyres.
either go et 40 or roll the rear arches.
If on a mk2, you can (if you dare) remove a fair bit of the front wing metal and remove metal from rear arches and seam weld it back up, doing this you can go 8" or even 9" wide rims (9" will need a bit of neg camber, but should just do it)
for the track I run 8x17 with 235 tyres and every time I look at it wish I had gone for 9" wide rims. You can't get full lock without rubbing the tyres on the front though.
kei force 10 them alloys are, i had some on my van and got rid of them :(
Discussion Starter · #9 ·
Cheers man I will look out for some. What's size did you go for btw? 17 j7?
18 inch on my van, think they were7.5j wide as i had 215 35 18 tyres
MG ZS180 MKII 5 Door
I have 18" wheels on my MK I ZS180 but you need 35 profile or lower to minimise scraping the tyres on the wheel arches.
Slightly taller gearing so when speed says 70 you are doing a genuine 70 mph. Care with cameras!!:twak2:
